Date/Time: Fri, 03 May 2024 20:04:32 +0000
Replay chart control panel missing
View Count: 2116
[2017-01-04 03:08:55] |
Leif - Posts: 9 |
I am trying to replay chart like I've done many times before, but the control panel no longer appears any where on the screen. I am using dual monitors. I tried moving around the sierra chart window but cannot find the control panel. I updated to current version but still same problem. I also tried "reset child windows" option. Any suggestions? Thanks |
[2017-01-04 03:58:05] |
Select Window >> Reset Windows.
[2017-01-04 05:51:24] |
Leif - Posts: 9 |
Thank you!
[2018-11-28 23:28:06] |
sectel - Posts: 12 |
Same issue as listed by another user "I am trying to replay chart like I've done many times before, but the control panel no longer appears any where on the screen. I am using dual monitors. I tried moving around the sierra chart window but cannot find the control panel. I updated to current version but still same problem. I also tried "reset child windows" option. Any suggestions?"" J. |
[2018-11-29 01:23:40] |
You need to use Window >> Reset Windows for the replay window.
