Date/Time: Sun, 05 May 2024 09:13:57 +0000
NZDUSD
View Count: 1356
[2013-08-06 00:49:43] |
user40663 - Posts: 54 |
Hi Just looking through some forex charts this morning and noticed that a bar on nzdusd is not showing correctly for daily charts. The second bar in from the right is showing incorrectly. Is there a way to fix this? Thanks |
Attachment Deleted. nzdusd.JPG / V - Attached On 2013-08-06 00:49:07 UTC - Size: 51.49 KB - 509 views |
[2013-08-06 01:40:37] |
We re-downloaded that data direct from FXCM, the data provider in this particular case, and the data is the same. So not sure what we can do about it. You can manually edit the data by following the instructions in help topic 2.2.1: http://www.sierrachart.com/index.php?l=doc/helpdetails2.html#h2.2.1 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-08-06 01:40:58
