Date/Time: Sat, 18 May 2024 23:30:38 +0000
Shift data forward or backward n periods with ACSIL
View Count: 758
[2017-01-02 15:10:38] |
User514837 - Posts: 47 |
How can I shift either an array (SCSubgraphRef) or a moving average calculation forward or backward using ACSIL? Another question is if there is any example of trading system using Senkou span A & B?
Date Time Of Last Edit: 2017-01-02 15:15:17
[2017-01-02 18:33:25] |
We can only refer you to this information: http://www.sierrachart.com/index.php?page=doc/ACS_ArraysAndLooping.html http://www.sierrachart.com/index.php?page=doc/ACSIL_Members_scSubgraph.html#scSubgraphDisplacement Another question is if there is any example of trading system using Senkou span A & B? No.
