Date/Time: Mon, 29 Apr 2024 02:29:44 +0000
Historical Backfill
View Count: 2159
[2013-04-03 03:53:08] |
Please see the following sections for help with this: http://www.sierrachart.com/index.php?l=doc/doc_ChartDataFiles.html#RenamingFiles http://www.sierrachart.com/index.php?l=doc/doc_ChartSettings.html#TimeRange How much tick data and how much Minute or Seconds data in a data file there is, is based upon many variables. It depends also upon the service you are using. So we cannot give an answer to this. You just have to look in the file by going to Edit >> Edit/Download Data-Intraday Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
