Date/Time: Sat, 18 May 2024 19:03:24 +0000
Chartbook per screen
View Count: 786
[2017-01-01 21:39:41] |
user8888 - Posts: 159 |
Hello, I'd like to close/open some different combinations of charts (chartbooks) in screen #1 while keeping other charts in screen #2, unchanged Is there any way to achieve this with Sierra? like if it were possible to create chartbooks per screen. Or should I create a 2nd instance just for this? Thank You |
[2017-01-01 21:59:37] |
Refer to this page: http://www.sierrachart.com/index.php?page=doc/DetachingandAttachingChartWindows.html Most likely you will want to use another instance. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-01-01 23:21:34] |
ok, regarding the 2nd instance: Can it share the "Data" folder of the 1st one? I'm going to chart the same symbols in both instances. Is there no conflict writing to the same files by the 2 Sierras? Thank you Date Time Of Last Edit: 2017-01-01 23:52:35
[2017-01-02 01:11:57] |
No. Otherwise, there will be conflicts.
