Date/Time: Sun, 19 May 2024 04:55:34 +0000
Numbers Bars -Two additional lines
View Count: 703
[2016-12-31 10:47:39] |
nicktrader - Posts: 665 |
It would be very helpful if you could add two "Input lines" as shown in screenshot. The lines are: - Bid/ Ask Volume Text Threshold Maximum - Bid/ Ask Volume Compare Threshold Maximum I'd like to use this study more than one time and to build groups with different colors. |
Study Numbers Bars - Maximum.png / V - Attached On 2016-12-31 10:44:54 UTC - Size: 21.61 KB - 220 views |
[2017-01-02 17:42:52] |
What exactly should this do and why?: - Bid/ Ask Volume Text Threshold Maximum - Bid/ Ask Volume Compare Threshold Maximum Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-01-02 17:43:26
