Date/Time: Thu, 09 May 2024 21:10:03 +0000
Values Inconsistent for Daily OHLC
View Count: 637
[2016-12-30 19:05:46] |
User287553 - Posts: 33 |
Hi Im using Sierra through AMP Futures, and noticed that the Open, High, Low, Close values for the Day are not matching with values on my Ninja charts. I've tried several times, but Sierra's values do not match. I'm using Intraday day chart for Crude Oil Feb 2017 futures. Appreciate your help. thanks. Jahanzeb 6478384003 |
[2016-12-30 19:21:36] |
Refer to the documentation here for this study: https://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s137 Make sure the Session Times in the chart are set correctly. Also the way that this needs to be analyzed, is not by comparing to another program, but instead by understanding what the study does and make sure it is properly configured and the data in the chart is accurate. All of this should be apparent just by looking at the time where the lines begin at for each day in the chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-12-30 19:22:26
