Date/Time: Mon, 13 May 2024 14:52:07 +0000
How to feed the excel file with realtime data tick by tick?
View Count: 978
[2016-12-30 16:45:02] |
User542865 - Posts: 2 |
I would like to link the real time data feed into multiple excel files with various time frames (30 minutes, 60 minutes, etc). How can I do it from Sierra Charts? I use AT Charts through Transact Futures Account. Thanks.
[2016-12-30 17:57:16] |
There are two things that you can do. You can use the Spreadsheet study: https://www.sierrachart.com/index.php?page=doc/SpreadsheetStudy.html Or you can use this study: https://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s182 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
