Date/Time: Mon, 14 Jul 2025 21:11:04 +0000
Different DMI Values using price overlay
View Count: 748
[2016-12-29 19:12:03]
AcquaLife - Posts: 33
Hello, I am using the price overlay method as described in http://www.sierrachart.com/index.php?page=doc/ACSILRefOtherTimeFrames.php. I am using the first example. Anyways, I can get it to work perfectly on simulation mode, however when i turn it live i have something quite different.
I have attached a picture to explain. Also, as i said i am using the code from the first example. BUT i have changed the moving average value to 1 so it just takes the average of the data at that point and i deleted the +10.
This is what your example shows
sc.Subgraph[0].Arrays[9][sc.Index] = RefStudyCurrentValue + 10;
sc.SimpleMovAvg(sc.Subgraph[0].Arrays[9],sc.Subgraph[0],15);
This is what i have done.
sc.Subgraph[0].Arrays[9][sc.Index] = RefStudyCurrentValue;
sc.SimpleMovAvg(sc.Subgraph[0].Arrays[9],sc.Subgraph[0],1);
I do not know if you need to know this information.
Thank you for your help!
[2016-12-29 19:16:13]
Here is the picture.
imagehelp.jpg / V - Attached On 2016-12-29 19:15:57 UTC - Size: 461.07 KB - 321 views
[2016-12-30 21:42:00]
We do not know what you mean by "simulation mode". Please explain.
You must also set sc.CalculationPrecedence = LOW_PREC_LEVEL; as is shown in the code example. Most likely this is the source of the problem. It must be something very basic.
Date Time Of Last Edit: 2016-12-30 21:43:06
