Date/Time: Fri, 10 May 2024 12:57:37 +0000
Multiple Alerts in Studies
View Count: 1048
[2016-12-29 16:36:51] |
JVonD - Posts: 9 |
This is probably a really stupid question. How do I put in multiple alerts in a single study? Example - In the DMI & ADX study I figured out the "SG1<10" but I can't figure out how to add the "SG2<10" without and error message. Thanks! ~J Date Time Of Last Edit: 2016-12-29 16:37:44
16-12-29_09-37-09.png / V - Attached On 2016-12-29 16:37:26 UTC - Size: 87.17 KB - 200 views |
[2016-12-29 18:18:05] |
You need to use the AND/OR functions: http://www.sierrachart.com/index.php?page=doc/StudyChartAlertsAndScanning.php#ORANDFunctions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-12-29 18:26:42] |
JVonD - Posts: 9 |
I saw that and tried a bunch of different codes, but I guess I'm to dumb to figure it out. SG1<10,andSG2<10 SG1<10=orSG2<10 Can you show me an example please? Thanks a lot! ~J (If I can't figure this out I'm probably to dumb to be a trader..) |
16-12-29_11-25-04.png / V - Attached On 2016-12-29 18:25:26 UTC - Size: 193.86 KB - 221 views |
[2016-12-29 18:52:04] |
These are the correct formulas. AND(SG1<10, SG2<10) OR(SG1<10, SG2<10) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-12-29 19:53:45] |
JVonD - Posts: 9 |
Perfect, thanks a lot! sorry, just saw the thing that says "don't say thanks".. "NOTED!" Date Time Of Last Edit: 2016-12-29 19:54:39
