Date/Time: Tue, 14 May 2024 11:41:50 +0000
Volume profile settings not able to see black font letters in:Entire Profile Ask-Bid Vol
View Count: 590
[2016-12-28 20:52:48] |
User252419 - Posts: 235 |
I have a white background. I have the option of Display Entire Profile Ask Volume- Bid Volume: Yes. When background is black I see the AV-BV:number. But when background is white I don't see it. I don't find the option to change the color of this setting in Subgraphs settings. Thank you, |
[2016-12-28 23:08:57] |
We do see this problem and this will be resolved in the next release.
