Date/Time: Sun, 12 May 2024 10:51:48 +0000
DOM Settings and Customization do not work
View Count: 685
[2016-12-28 08:15:00] |
nicktrader - Posts: 665 |
As you can see in the screenshot wether DOM Settings nor customization do not work I am using release 1500 Date Time Of Last Edit: 2016-12-28 09:37:34
DOM Settings.png / V - Attached On 2016-12-28 08:13:57 UTC - Size: 135.26 KB - 209 views |
[2016-12-28 09:40:44] |
You are modifying the Chart DOM columns and not the Trade DOM columns. You need to use Global Settings >> Customize Trade DOM Columns instead. And you need to add the Bid Size and Ask Size columns as well. Refer to: Chart Trading and the Chart DOM: Customizing Trade DOM and Chart DOM Columns Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-12-28 17:57:12] |
okay, my fault. But what about DOM Settings? Nothing of the choosen fields like "DOM Depth Total" or "Percentages" are displayed. |
[2016-12-28 22:18:50] |
Those settings will not do anything unless the Bid Size and Ask Size columns have been added to the Chart/Trade DOM.
