Date/Time: Thu, 02 May 2024 13:50:44 +0000
FX tick size
View Count: 1597
[2013-08-05 18:35:59] |
AndyL - Posts: 119 |
Sierra FX datafeeds (lmax and fxcm) come with a 5th decimal place. Is it possible to set up a chart that rounds everything(and draws charts) to a full pip (only 4 decimal places) ? I can set 'Price display format' to 4 decimal places, but this seems only to affect the price labels displayed on the right hand scale - charts still draw with 5 decimal precision. Altering the 'Ticks Size' setting does not appear to change this behaviour either. Best regards, Andy |
[2013-08-05 23:09:08] |
Use the Round Price Bars to Tick Size study.
[2013-08-05 23:32:20] |
Thanks, its exactly what i was trying to do.
