Date/Time: Sat, 11 May 2024 07:54:43 +0000
How to color background between 2 EMA's crossover area
View Count: 3070
[2016-12-27 18:01:32] |
User396743 - Posts: 3 |
Hi, I have 2 different period EMA's (say 5 and 12 period) charted on the graph. I want to have Sierra color the background ares of their crossover so that when EMA5 crosses below EMA12, the area bound by those 2 EMAs is colored yellow (undercross) while when EMA5 crosses over EMA12, the background area on the chart bound by those 2 EMA's is colored blue. I don't want the SC to paint the bar any color or to have thick vertical line run through the bar that crosses. I specifically need only background area between the 2 EMA's to be colored. Please see either the image in the link or the attachment for visual representation of what I'm trying to achieve (areas shaded in yellow and red in the pictures): http://www.forexfactory.com/attachment.php?attachmentid=452837&d=1270641454 I have found a way to paint the bar upon crossover or the make a vertical thick line but not how to color the background within the crossover of the 2 EMA's. Can you please tell me either if there is an existing study that could accomplish it (I have found EMA crossover study but I fail to see how it can do what I need) or suggest the code to paste into code editor/spreadsheet creator to do it? Your help will be much appreciated. |
EMA Crossover color background between EMA.jpg / V - Attached On 2016-12-27 17:58:25 UTC - Size: 184.63 KB - 518 views |
[2016-12-27 19:06:00] |
Here is the documentation for how to do this: http://www.sierrachart.com/index.php?page=doc/ChartStudies.html#FillingArea Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-12-29 09:11:53] |
User84094 - Posts: 43 |
You have already bulit in study for that FlexMA
[2016-12-29 15:11:10] |
User630996 - Posts: 25 |
Where exactly is this "FlexMA"?
[2016-12-29 18:25:16] |
We do not know what the user is referring to.
[2016-12-30 12:26:16] |
User Contributed Studies Flexible MAs |
