Date/Time: Sun, 12 May 2024 11:17:31 +0000
Chart DON P&L not showing position value in currency
View Count: 2622
[2016-12-27 16:06:34] |
User360283 - Posts: 440 |
Chart DOM position value keeps showing as Points. Chart Setting > Advance Settings > Position P&L is Currency I have tried clicking clicking on the P&L at the top of the Chart DOM - nothing happens Help please |
[2016-12-27 19:00:10] |
Are you referring to the Open Profit/Loss value? What is the symbol of the chart? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-12-27 19:06:21] |
The p&l that shows in the Chart DOM for the current position in Points or Currency. Note that I've had it set for Currency (USD) for weeks. Today it changed to Points. I do not know how this happened and can't figure out to get it back to Currency thanks CQG F.US.EPH17 |
[2016-12-27 19:13:39] |
What is Chart >> Chart Settings >> Advanced Settings 2 >> Currency Value per Tick set to?
[2016-12-27 23:58:50] |
12.5
[2016-12-28 03:17:05] |
Do you see the Open Profit/Loss reported as a Currency value on the Trade Window. Refer to: http://www.sierrachart.com/index.php?page=doc/TradeWindow.html#OpenProfitLoss Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-12-28 04:35:10] |
Yes - top of chart shows P&L is currency $ Also Trade Window for Chart shows as currency $ It's only the Chart DOm that is showing Points |
[2016-12-28 09:45:02] |
We need to look into this.
[2016-12-28 13:33:01] |
OK, Thanks. BTW, I think that when one has multiple ES contracts open and General Trade Settings > LIFO is set, the Chart DOM displayed value in currency or points is not accurate. Will you please check or clarify? |
[2016-12-28 18:20:29] |
I installed the most current version today and the Chart DOM display of P%L is working correct;y. I can toggle through display formats by clicking on the "P&L" at the column top.
[2016-12-28 18:38:55] |
The Position Average Price Calculation is correct based upon how it is determined and the available order fill data it is based upon. This section here explains this in detail: http://www.sierrachart.com/index.php?page=doc/TradeStatusWindows.html#OrderFillCalculatedAveragePrice Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-12-28 18:39:12
