Date/Time: Sun, 05 May 2024 10:49:36 +0000
Is it Possible to displace a chartbook in another screen
View Count: 2136
[2016-12-24 16:41:02] |
sierra28 - Posts: 120 |
...with only an instance of Sierra ? Need to see two chartbooks at same time thanks |
[2016-12-24 20:38:26] |
If you want to see two Chartbooks at the same time, you need to use the New Instance feature: http://www.sierrachart.com/index.php?page=doc/DTCServer.php#UsingDTCServerForDataAndTradingInAnotherSCInstance Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
