Date/Time: Sun, 01 Nov 2026 21:39:54 +0000
Horizontal lines
View Count: 1375
| [2016-12-21 05:43:24] |
| User226486 - Posts: 27 |
I would like to create horizontal lines on my chart for the below expansion targets, which will update every day. previous high +(previous high - previous close) x.25 x.50 x.75 previous low - (previous high - previous close) x.25 x.50 X.75 So a total of 8 lines Could you please help? Date Time Of Last Edit: 2016-12-21 07:24:26
| [2016-12-21 05:59:31] |
When you say Previous High and Previous Close are you referring to the prior day high and close? Kind of looks like a Pivot Point type of formula. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-12-21 06:01:19] |
Yes, prior day high and close. Thankyou |
| [2016-12-21 10:15:49] |
Have a look at using this study: https://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s294 (Previous/Period OHLC-Variable Period) And then using the arithmetic studies to do these calculations: Using the Basic Arithmetic Studies However, these are Pivot Point type of calculations and we could add this formula to the Pivot Points-Daily study if it is something which is not going to keep changing. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-12-21 13:45:33] |
It will only change on the next day, is this something that could be added. many thanks
| [2016-12-21 13:56:32] |
| Sawtooth - Posts: 4359 |
It looks like an expansion of Pivot Point Formula Type 16. http://www.sierrachart.com/index.php?page=doc/PivotPoints.html#PPFormulas Without a new PP formula, the easiest way to do this is with the Spreadsheet Study study. |
| [2016-12-21 18:28:18] |
Yes, we can add this formula. We will get this done today.
| [2016-12-21 19:09:51] |
This formula will be Formula Type 25 and will be in the next release.
| [2016-12-21 19:52:16] |
Thankyou very much for doing this and for such a quick response!
| [2017-01-11 12:41:09] |
Hi, is there any chance i could have this also for a weekly and monthly? I see i can input the values manually.
| [2017-01-11 18:29:04] |
Yes, use this study: http://www.sierrachart.com/index.php?page=doc/PivotPoints.html#s223 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-01-11 18:34:13
| [2017-01-11 18:53:44] |
Got it, thankyou!!
