Date/Time: Sun, 19 May 2024 10:52:24 +0000
Chart Trader GTC orders
View Count: 1010
[2016-12-20 15:37:18] |
User593033 - Posts: 10 |
I am having trouble finding where i can check the global chart trader settings to determine if my orders are set to GTC. The problem I had was I had four buy and sell orders on my charts that disappeared after the SC closed and reopened. I did not have that issue last week when I shut down SC and restarted it. So, I am thinking that perhaps the orders are set to expire after a given amount of time ? Thank you |
[2016-12-20 18:27:08] |
The Time in Force is a Trade Window setting. Refer to: http://www.sierrachart.com/index.php?page=doc/TradeWindow.html#TradeWindowControls Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
