Date/Time: Sat, 04 May 2024 15:31:36 +0000
Widening the region boundary lines
View Count: 1450
[2013-08-05 10:03:05] |
SKY - Posts: 45 |
Can i widen the region lines and set their color ? could not find such acapability in teh graphics configuration entries Tnx! |
[2013-08-05 10:06:55] |
These are a single pixel wide and they use the Chart Scale Border color.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-08-05 10:07:09
[2013-08-05 11:23:34] |
SKY - Posts: 45 |
can you PLS support widening it I really need it (and i assume i'm not teh only one) i need it to be bold and clear as it is loast between various price levels that appera on the chart (and i work w/ clean cahrts - no indicators and that stuff ... so others need to go thru) Tnx! |
