Date/Time: Sun, 19 May 2024 10:32:05 +0000
Horizontal Line at Time
View Count: 1277
[2016-12-19 08:10:26] |
User19165 - Posts: 346 |
Hello, I was doing some study over the weekend using the Horizontal Line At Time indicator and wondered if I may be using it wrong? I have just entered in a start time and set the use stop time to be NO. My understanding was that the indicator should draw a horizontal line until the next start time is encountered. This mostly happens except on a Friday where the horizontal line does not continue into the Monday. Is that the intended behavior? https://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s306 With kind regards, MK |
[2016-12-20 01:02:23] |
We need to see a chart image showing Friday and Monday. Here are instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-12-20 01:57:41] |
OK, sorry for not doing this initially. As you can see, the line does not persist drawing into every Monday.
MK-2016-12-20_145504.png / V - Attached On 2016-12-20 01:57:27 UTC - Size: 55.9 KB - 394 views |
[2016-12-21 18:36:16] |
We looked into this, and the Horizontal line does not extend beyond 24 hours from the starting time. In the next release, this study Input will be added to work around this: Limit Horizontal Line From Time To 1 Day You will want to set this to No. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-12-21 18:36:52
