Date/Time: Fri, 03 May 2024 18:44:11 +0000
use of GDT_CANDLESTICK
View Count: 1499
[2013-08-04 22:36:27] |
maxpi - Posts: 175 |
GDT_CANDLESTICK works fine when there is a 1:1 correlation between the studys' bars and the charts' bars. Under those conditions it works fine when displayed as the main price graph as well. I'm generating a series of bars in a study that don't start/end at the same time as the displayed bars and they don't have the same bar interval as the main price graph. Would it be possible to use these generated bars as the main price graph? Drawing them on a faster bar interval chart and scaling it's bar interval would be one application I would have if the GDT_CANDLESTICK choice would work under those conditions. The idea is I can pull these bars out of cyberspace, display them as the main price graph and subsequently use them for drawings and further calculations in other studies.
[2013-08-04 23:10:32] |
You need to use sc.IsCustomChart: http://www.sierrachart.com/index.php?l=doc/doc_ACSIL_Members.html#scIsCustomChart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
