Date/Time: Sat, 18 May 2024 21:05:15 +0000
Global Chart Drawings Shortcut Menu Missing the New 24 Configs
View Count: 635
[2016-12-16 12:21:33] |
Trader Ra - Posts: 87 |
SC recently added support for 24 customizable configurations for drawings.. up from 8 before. I would like to add these configurations to the chart drawings shortcut menu. Currently I can't add more than the previous 8 when I go into its Global settings. Am I missing something? Shouldn't all the 24 configuration options show up in global settings for chart drawings ? Goal is to be able to easily right click on a drawing and select a chosen configuration from the new 24 options. |
[2016-12-16 18:29:04] |
We will add this.
