Date/Time: Sun, 19 May 2024 06:11:23 +0000
Intraday Data Editor
View Count: 700
[2016-12-16 01:16:43] |
User760942 - Posts: 120 |
Hi SC, I set my "Intraday Data Storage Time Unit" to 1 tick (as shown in 1.jpg), downloaded an intraday data file, then opened the "Intraday Data Editor" via pressing the button shown in 2.jpg and was brought to 3.jpg. Does the area circled in blue in 3.jpg represent 1 tick? If so, what do the numbers circled in Red in 3.jpg represent? Shouldn't the numbers circled in red be the same as the number circled in blue? Date Time Of Last Edit: 2016-12-16 01:26:13
Attachment Deleted. |
[2016-12-16 05:21:36] |
What you are looking at is 1 Tick data and this is explained in more detail here: Intraday Data Editor: Editor Controls Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
