Date/Time: Sun, 19 May 2024 04:55:40 +0000
lock fill space
View Count: 1545
[2016-12-15 15:21:09] |
User170575 - Posts: 221 |
Good morning, I have the LFS on but my bars are still filling out of the viusual chart range--what am i missing? filling out of range here http://www.sierrachart.com/image.php?Image=1481815116536.png after adjustment(sliding the bar over on the bottom) http://www.sierrachart.com/image.php?Image=1481815174336.png Many thanks, Cy |
[2016-12-15 18:09:57] |
We are not understanding this: I have the LFS on but my bars are still filling out of the viusual chart range--what am i missing? We do not see anything unusual in those chart images in regards to the fill space. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-12-15 18:10:23
[2016-12-15 18:16:36] |
Sorry---i am not explaining this correctly---I have to drag the slide at the bottom of the chart to the right to see all off the bars---I thought the LFS was suppose to prevent this. Plz see attached. Thx Cy |
Attachment Deleted. |
[2016-12-15 18:20:05] |
If you drag the scrollbar box towards the right until it stops, that is going to cause the most recent bars to display. We are still not understanding this. Anyway, the behavior as it is, is correct. Is there a problem where the chart is scrolling back inadvertently? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-12-15 18:20:58
[2016-12-15 18:21:08] |
The prior post has been updated.
[2016-12-16 14:21:48] |
"Is there a problem where the chart is scrolling back inadvertently? " Yes, I have open 10-12 chart books, each with a chart. All have the LFS on but still some charts will build out of range with the scroll bar not locked to the right side. I wonder if the way I access the chart that may release the LFS? Rather than click on the chartbook tab I often use the Alert Manager and just double click the alert to go to the chart. Many thx, Cy |
[2016-12-16 17:55:51] |
First of all, there is no way to lock the scrollbar. That kind of functionality does not exist. I wonder if the way I access the chart
Yes this is a problem. Do not do this.
that may release the LFS? Rather than click on the chartbook tab I often use the Alert Manager and just double click the alert to go to the chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-12-16 18:15:01] |
Many thanks---FYI---it appears the "Go to Chart" button is guilty also. Cy |
