Date/Time: Sun, 19 May 2024 07:44:38 +0000
historical depth request !!!
View Count: 733
[2016-12-15 01:07:15] |
zippyzip - Posts: 293 |
can we get an option to get rid of the zeros ? thanks
Private File |
[2016-12-15 02:12:16] |
Yes, set this input with the Study to 1 or greater: http://www.sierrachart.com/index.php?page=doc/MarketDepthHistoricalGraph.php#StudyInputs_GraphOnlyQuantitiesGreaterOrEqualTo Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-12-15 02:24:03] |
not sure i under stand as i have that setting set at 1250 but im still getting all zeros ,
Private File |
[2016-12-15 10:03:37] |
We need to check on this.
[2016-12-16 00:31:34] |
This should be resolved in the next release.
