Date/Time: Sun, 26 May 2024 13:41:14 +0000
Open a new instance on my second pc
View Count: 727
[2016-12-14 21:28:45] |
User1193154 - Posts: 54 |
Hello, I tried to open another instance on my second computer to see another time-frame chart (same ip and adsl). It starts but doent update values, in poor words doesnt work. Is a subscrption problem? Regards, Flavia |
[2016-12-14 21:31:20] |
Did you want to use two instances of Sierra Chart at the same time?
[2016-12-17 02:51:58] |
Yes, but without trade function. Ty |
[2016-12-17 10:41:36] |
You need to activate a second real-time connection for the Sierra Chart Exchange Data Feed. Refer to: Sierra Chart Exchange Data Feed: Connections And you will need to install another copy of Sierra Chart on your other system. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
