Date/Time: Sun, 19 May 2024 07:45:10 +0000
Continuous Contract for DAX e MINI
View Count: 1020
[2016-12-08 18:11:13] |
ripsdips - Posts: 143 |
is there any way I can view the DAX e MINI in a continuous form? Meaning not to switch to the upcoming March contract.
[2016-12-08 18:35:32] |
Yes. Follow through the instructions here: http://www.sierrachart.com/index.php?page=doc/ContinuousFuturesContractCharts.html Meaning not to switch to the upcoming March contract. We do not know what you mean by this, but we do not see it as relevant anyway.
[2016-12-09 03:16:31] |
User19165 - Posts: 346 |
He wants a continuous contract symbol. Note, this need not be a symbol from your datafeed but could be handled internally within the charting application. Several other charting apps handle it this way. This is quite convenient, especially if one is involved in many markets. |
[2016-12-09 04:14:39] |
You just need to follow through the instructions here: http://www.sierrachart.com/index.php?page=doc/ContinuousFuturesContractCharts.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-12-09 04:45:26] |
OK then, just so I am clear here is an example: Th IB symbol GBM-201612-DTB has a rollover setting of 2 business days before the 10th of the rollover month. That would make it the 8th of DEC 2016. The advanced settings in my chart has it set to date rule rollover, back adjusted. This should have rolled over automatically on the 8th? |
[2016-12-09 05:36:09] |
To do what you want, refer to this particular Chart Setting: https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#AutomaticallyRollover Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
