Date/Time: Fri, 03 May 2024 07:27:46 +0000
How to use data from Chart 2 on Worksheet attached to Chart
View Count: 1417
[2013-08-02 20:09:16] |
William F - Posts: 6 |
I have a chartbook that contains 2 charts. Chart 1 has a worksheet attached to it. Can I use data from chsrt 2 in this worksheet and if so, how to?
[2013-08-02 21:35:16] |
Sawtooth - Posts: 3992 |
The supported solution is to use the Study/Price Overlay study on chart 1, to overlay chart 2's data. http://www.sierrachart.com/index.php?l=doc/doc_ReferencingChartsFormulas.html#OverlayStudies The unsupported solution is to add the same-named spreadsheet to chart 2, and inter-reference the cells on each sheet. This works in certain configurations, but there can be synchronization issues. |
[2013-08-02 21:46:36] |
The answer given in post #2 is correct.
