Date/Time: Sun, 19 May 2024 01:39:19 +0000
Trying to have a triple array
View Count: 777
[2016-12-06 18:57:29] |
User994967 - Posts: 1 |
Hello, i'm currently trying to write a peace of code that should do something like this: create a triple array, something like: double triplearray[][][]; <<<of course this is not sierrachart programming language the 3 dimensions of the array would be used like [sc.Index][numberfrom0to10][numberfrom0to10]. error C2109: subscript requires array or pointer type What can be a correct way to do it? Thanks very much. Edit: i solved the situation by doing many two dimensional arrays instead of a single big three dimensional array. Date Time Of Last Edit: 2016-12-06 22:09:32
[2016-12-06 22:49:19] |
A three-dimensional array like this is difficult and that is not something we can help with. The best we can recommend is to use the Arrays member on each study Subgraph: ACSIL Interface Members - sc.Subgraph Array: sc.Subgraph[].Arrays[][] Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
