Date/Time: Sun, 19 May 2024 04:37:22 +0000
Volume by Price study Performance issues
View Count: 775
[2016-12-05 16:26:00] |
Johnny - Posts: 99 |
Hello, the platform becomes laggy whenever i connect to a real-time service and there's at least one chart in the chartbook that has a timeframe above 30M and the VbP study loaded to it. The higher the timeframe the more laggy the platform gets. Moreover, it takes a big amount of time to scroll back a chart especially when you add two or more VbP studies.
[2016-12-05 18:06:37] |
Scroll the chart to where you can see one of the volume profiles and post an image of the chart following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image Also refer to these 2 sections: http://www.sierrachart.com/index.php?page=doc/helpdetails30.html#h30.23 http://www.sierrachart.com/index.php?page=doc/helpdetails30.html#h30.35 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-12-09 01:28:43] |
I'm aware of these instructions. Is there any room for optimization from your side? http://www.sierrachart.com/image.php?Image=1481246871772.png |
[2016-12-09 01:41:17] |
No. If you do not want to increase the Ticks per Volume Bar, we cannot help with this.
