Date/Time: Wed, 15 May 2024 07:19:45 +0000
sc.ChartBackgroundColor does not seem to work
View Count: 638
[2016-12-03 16:06:36] |
@sstfrederik - Posts: 403 |
I have a simple example of sc.ChartBackgroundColor, but it does not work. I did set sc.UseGlobalChartColors = 0; in the default block. Do I miss anything? Thanks. |
[2016-12-03 21:51:41] |
Refer to: ACSIL Interface Members - Variables and Arrays: sc.UseGlobalChartColors Since sc.UseGlobalChartColors affects the chart itself, it must be located outside and below the sc.SetDefaults code block.
