Date/Time: Tue, 14 May 2024 20:21:50 +0000
Problem with "Copy Column J from Formula Source Sheet"
View Count: 996
[2016-12-02 19:55:20] |
User260310 - Posts: 6 |
I would like to use the "Copy Column J from Formula Source Sheet" setting to copy Column J cells from Sheet1 in my spreadsheet system to a new sheet for a different futures symbol. However, when I do this, cells which I rely on for accurate information in Column J receive values from Sheet1, even though it does not make sense to do so. For example, cell J21 will show the tick size for the contract of Sheet1 instead of the correct tick size for the new symbol. This does not make sense, as the tick size Cell should always contain the tick size for the contract on which the sheet is based, should it not? Please advise if this is an error in the software and if it will be fixed.
[2016-12-02 22:13:12] |
We will look into this.
[2016-12-03 18:17:50] |
phaedonk - Posts: 352 |
Yes, I wanted to write the same thing. What Sierra must do is only copy the write cells, not the read-only ones.
[2016-12-03 19:45:36] |
Exactly, phaedonk. I would also like it to copy several cells below row 101 (including the labels in row I, if possible), which I use for custom entries that don't need to be repeated for each bar.
[2016-12-03 21:11:47] |
This will be solved. We will consider #4. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
