Date/Time: Wed, 15 May 2024 09:39:38 +0000
Column J Default Values
View Count: 740
[2016-12-02 17:43:11] |
User260310 - Posts: 6 |
Is there a place where one can change the default values of the read/write cells in Column J in a spreadsheet system for trading? It would be really helpful if I did not have to input my preferred settings every time I create a new spreadsheet. Instead, manage the defaults in an "INI" text file or similar location in the Sierra Chart folder.
[2016-12-02 17:52:45] |
No, there are no defaults that can be changed.
[2016-12-02 18:14:51] |
Sawtooth - Posts: 3996 |
In the Study Setting, at the bottom of the Settings and Inputs tab, there is a check box to 'Save These Settings as the Default'
[2016-12-02 18:19:33] |
We do not see how that is going to affect read/write values on the Spreadsheet in column J.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-12-02 18:19:42
[2016-12-02 18:21:31] |
Only the (read-only) cells.
[2016-12-02 18:26:39] |
Yes, that is correct.
