Date/Time: Tue, 14 May 2024 14:54:56 +0000
TF Russell price multiplier reduction for futures
View Count: 1089
[2016-12-02 10:45:54] |
User295967 - Posts: 32 |
As of dec 5th the price multiplier for all Russell futures contracts will be reduced from $100 to $50. Minimum tick will remain at .10 index points and be equal to $ 5.00 per contract. QUESTION: I use chart DOM in SC. What steps should I do in SC to implement these changes from ICE? When should I implement the steps? Or is it all done automatically by SC? |
[2016-12-02 17:35:27] |
The only thing that is going to change is the Currency Value per Tick for the TF and we will be doing that after the close today. Sunday evening what we recommend that you do is update the symbol settings following the instructions here: Global Symbol Settings: Update Global Symbol Settings And then follow the instructions here to apply them to the chart: Global Symbol Settings: Update/Apply Symbol Settings to Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
