Date/Time: Tue, 14 May 2024 06:13:55 +0000
Referencing bid/ask Volume traded at the high or low of a bar
View Count: 694
[2016-12-02 04:13:06] |
User910917 - Posts: 1 |
Hello, is it possible to reference the Total Bid Volume or Ask Volume traded only at the High or low of a bar? just like we can reference the point of control volume in the Numbers Bars Calculated Values study. I am interested in the volume traded not the price level to do some calculation using your alert system. Thank you |
[2016-12-02 18:14:06] |
This data can be accessed in the Chart and Study Alert Formulas. There are functions for this documented here: Study/Chart Alerts And Scanning: Special Functions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
