Date/Time: Sat, 15 Aug 2026 01:09:46 +0000
IB not connecting with ver. 1003
View Count: 2606
| [2013-08-02 07:15:52] |
| Tonkadad - Posts: 235 |
I upgraded to ver. 1003 IB won't connect. TWS Build 922.6 Jan 5, 2012 Had to downgrade to 997 to connect. |
| [2013-08-02 10:39:21] |
You will need to update to TWS 9392 or higher from this page: https://www.interactivebrokers.com/en/index.php?f=674 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
