Date/Time: Sun, 28 Apr 2024 09:28:47 +0000
Change default connection DTS Data/Trade Service on startup
View Count: 983
[2016-12-02 00:15:48] |
User325580 - Posts: 2 |
Currently when I start SC it defaults to an older CQG FIX connection. I am currently using AMP/TTNet and each time I restart the program it resets the connection to CQG. How do I make it default to AMP/TTNet?
[2016-12-02 00:21:15] |
We have set your account not to automatically use CQG. So the last saved Service setting is what will be used.
[2016-12-07 18:01:14] |
AMP is phasing out TTNet for SC and so I had to switch to Rithmic, but my account is defaulting back to CQG again. Anyway to undo that?
[2016-12-07 21:02:34] |
This is now solved for your account.
[2017-01-22 21:15:07] |
f0rex - Posts: 2 |
I have similar problem. SC use CQG FIX after startup and I would like to have it to Rithmic as my default DTS. Can you fix it for me too? Thank you.
[2017-01-22 22:31:11] |
Yes this is now done for your account.
[2017-11-26 21:58:50] |
User888488 - Posts: 6 |
I have the same issue. I am now with Rithmic, but my default startup is reverting to CQG. Please help and thank you!
[2017-11-26 22:15:40] |
This is now resolved for your account.
