Date/Time: Tue, 14 May 2024 17:03:11 +0000
How to see options in the platform
View Count: 603
[2016-11-29 20:24:43] |
User514837 - Posts: 47 |
Hello, I know it is possible to see and trade options on the platform, but I am not sure where from. Could you please explain?
[2016-11-29 20:58:07] |
This is too vague for us to help with. What Data or Trading service are you using or do you wish to use? See this page for the list: https://www.sierrachart.com/index.php?l=doc/Data.php&CAID=def Or, if you heard about Sierra Chart from a trading/broker service and want to use their service with Sierra Chart, tell us which one you were referred from. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-11-29 21:15:49] |
I was using the demo Sierra platform with the SC - All Data feed. I'm guessing this is why I don't see any such option. I am also guessing that with Interactive Brokers it would be possible? What about Rithmic/CQG?
[2016-11-29 22:26:11] |
Did you want to look at futures options? Options are supported with both Interactive Brokers, Rithmic and CQG. In all cases it is just a matter of entering the proper symbol according to the required format for the particular Data or Trading service being used. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
