Date/Time: Wed, 15 May 2024 04:23:48 +0000
Chart Drawing Properties
View Count: 752
[2016-11-29 18:24:37] |
distilledmatt - Posts: 10 |
I posted this request/question under the "manage chart drawings" feed as well, so apologies if catching it twice. Alas, is it possible to enable the Date Box under Chart Drawing Properties > Labels for display purposes? It would be great to have a date attached to the Horizontal Ray's I use to quickly ascertain when I drew them. I'm guessing this would be difficult for some lines, but the Horizontal Ray for example could be configured to display the date from where it started.
[2016-11-29 18:33:46] |
No, this is not supported. It is not something simple to add.
[2016-11-29 20:13:31] |
User84163 - Posts: 17 |
Would be a GREAT ADDITION totally agree If you have some spare time 🦈🦈 needs to eat and that would make it easier then me having to click line, modify text Unless I'm missing something???
