Date/Time: Tue, 14 May 2024 06:08:52 +0000
Order Entry
View Count: 650
[2016-11-29 18:13:12] |
User426107 - Posts: 9 |
Hello I am using Sierra DOM for my execution. Is there a way for me to save order strategies with certain point stops and targets and then just select it and enter the order at a specific price. So say I save a strategy that would be a bracketed OCO with a 3 point stop and 6 point target and some certain number of contracts and then I have another one that is a 4 point stop etc. How can I do this? |
[2016-11-29 18:22:14] |
Refer to: Basic Trading and the Trade Window: Saving Trade Window Configuration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
