Date/Time: Sun, 05 May 2024 10:23:26 +0000
Pre-release
View Count: 1887
[2013-08-01 16:36:54] |
User29707 - Posts: 43 |
After downloading the pre-release version this morning and installing it, SC would not connect to the SC server. All of my login and data setting are correct.
[2013-08-01 16:50:13] |
We see you are using Interactive Brokers. So the problem is you need to update to the latest TWS to connect. Go to this page and get TWS version 9392 or higher: https://www.interactivebrokers.com/en/index.php?f=674 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
