Date/Time: Wed, 15 May 2024 03:55:41 +0000
Mac iOS
View Count: 1899
[2016-11-28 10:25:27] |
User357236 - Posts: 9 |
Hello, I have connected Sierra Chart with IB. I would like to ask whether the Sierra Chart is compatible with Mac iOS or not. I was told that IB is compatible but I do not know of Sierra Chart. Thank you Michal |
[2016-11-28 18:17:11] |
Sierra Chart cannot run on the Mac IOS directly. You would need to use a program like Parallels to run Windows which then Sierra Chart needs to run on.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-11-28 18:17:26
