Date/Time: Thu, 16 May 2024 02:50:51 +0000
Update Notifications
View Count: 813
[2016-11-27 17:28:17] |
User104854 - Posts: 441 |
Hi. Is there a way to get notifications when a new software update is released? An email perhaps? Is there a setting somewhere that I can activate? Please advise, John |
[2016-11-27 19:16:18] |
No.
[2016-11-27 19:36:17] |
Sometimes update notifications are put out but not frequently. Generally about every couple of months.
[2016-11-27 19:50:53] |
So then what's the best way to find out if there's been an update or if I'm using the most recent version? Are there descriptions of what's changed with the latest version anywhere?
[2016-11-28 00:49:59] |
You can use Help >> Download Current Version. Also have a look at this page: https://www.sierrachart.com/index.php?page=doc/Whats_New.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-11-28 21:22:57] |
That helps. Thank you.
