Date/Time: Sun, 19 May 2024 02:17:34 +0000
Initial balance study
View Count: 1875
[2016-11-25 16:26:42] |
User93534 - Posts: 30 |
Is it possible to get a stop time to terminate the drawing rather than have the extensions print for a full 24 hours? For example, if I want to use multiple balance periods throughout the day, say first 30 minutes but only want the drawing to print for 4 hours at which point I want to use a different initial balance for a new session. As in, can there be a stop time for the initial balance study terminate the drawing like is available in the horizontal line at time study? It would be very helpful. Hiding the studies resets the drawings that have printed and require replaying the chart. I have made work arounds for this but it's resulting in using 150+ of the study subgraph add/difference/multiply studies and bogging down performance. |
[2016-11-25 22:23:13] |
There will be a new input added to the High/Low for Time Period-Extended study to support this. We are only willing to add this to that study. This will be out in the next release. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-11-25 23:19:26] |
Will the study have extension multipliers? If not then it won't help, the Hi low for time period study is one of the work arounds I use to print short extension multiplier levels, still requires difference, multiply, add/difference for every level so it is min. 14 studies per what a single IB study is capable of.
[2016-11-27 09:17:32] |
No it does not. But it is easy enough to use those additional studies to create those. If we have a chance we will look at the Initial Balance study itself. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
