Date/Time: Sat, 04 May 2024 00:06:55 +0000
Numbers Bars Values
View Count: 2013
[2013-04-01 18:27:58] |
mattb - Posts: 30 |
Recently experimenting with IQfeed data. something seems to be out of order with numbers bars values. showing many repetitive values within the bar, as well as unordinary values at swing hi's and low's. not arguing with the data, but it is obviously different than before. Switched back to Rithmic, and getting same results. attached is a screenshot. If you think it may just be a settings issue, please advise. thanks,matt http://www.sierrachart.com/Download.php?Folder=SupportBoard&download=118 |
Attachment Deleted. Attachment Deleted. 2013-04-01_0850footprint.png / V - Attached On 2013-04-01 18:25:48 UTC - Size: 82.56 KB - 1152 views |
[2013-04-01 19:30:53] |
Follow the instructions here for tick by tick Intraday data configuration: http://www.sierrachart.com/index.php?l=doc/doc_TickbyTickDataConfiguration.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-04-01 19:31:22
