Date/Time: Sun, 19 May 2024 21:13:45 +0000
ASCIL: Why is sc.NumberOfTrades[] the same as sc.OpenInterest[]?
View Count: 695
[2016-11-23 08:21:35] |
User129630 - Posts: 22 |
Not sure if this is a bug at Sierra Chart or data provider or others. I dumped out the bar data and find out sc.NumberOfTrades[] is the same (number-wise) as the sc.OpenInterest[]. They shouldn't be the same by definition. Please provide any insight. Thanks.
[2016-11-23 08:29:29] |
They share the same data array. OpenInterest is only for Historical Daily charts. Not for Intraday charts. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
