Date/Time: Sun, 19 May 2024 15:52:28 +0000
[Programming Help] - Scale or interval trading
View Count: 1285
[2016-11-22 12:04:15] |
User345323 - Posts: 18 |
Hello, is it possible with SC to do scale (interval) trading? I've looked on the different type of orders or on the Studies but i have found nothing for my needs. To explain better i make a simple example: PRICE @ 10 BUY PRICE @ 9 BUY PRICE @ 8 BUY PRICE @ 9 SELL PRICE @ 8 BUY PRICE @ 7 BUY PRICE @ 8 SELL ... ... Or is it possible to make this with Spreadsheet for automated trading? Thanks for the help Bye |
[2016-11-22 17:55:53] |
We do not understand this.
[2016-11-22 18:27:09] |
Really?? I think is very simple but i'll try to explain better with a link http://www.investopedia.com/terms/s/scale-in.asp For information on Trader Workstation of Interactive Brokers this function is called Scale Trader. Do you think is possible to do this with Sierra Chart? I think Sierra Chart is more powerfull than Trader Workstation. |
[2016-11-22 18:34:17] |
Not sure if this is what you are looking for but Sierra Chart does have a Scale In feature for Attached Orders: http://www.sierrachart.com/index.php?page=doc/AttachedOrders.html#ScalingIn Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-11-22 18:50:45] |
No unfortunately it isn't. Your feature change only the attached orders. It's really strange SC doesn't allow this kind of strategy. Do you think SC will include this in next release? |
[2016-11-22 18:58:28] |
No, there are no plans for this.
[2016-11-22 19:04:34] |
Any user can help me with a simple code to start? Thanks for the help |
