Date/Time: Sun, 19 May 2024 16:25:47 +0000
ACSIL sc.AddMessageToLog logs but do not pop
View Count: 825
[2016-11-22 10:09:42] |
wwwingman - Posts: 185 |
Hi When using the ACSIL sc.AddMessageToLog function the message appears in the log, but the log window do not pop up. sc.AddMessageToLog("This line of text will be added to the Message Log, and this call will show the Message Log.", 1);
Is there an option I need to activate somewhere ? Have I missed something ? -- W. |
[2016-11-22 10:39:24] |
Is the Message Log window already open or minimized?
[2016-11-22 10:42:37] |
No. Not open, nor minimized. FWIW I use the 1488 version but already hade this problem on previous versions. -- W. |
[2016-11-22 10:44:32] |
OK we are checking on this.
[2016-11-22 10:47:37] |
This will be resolved in the next release.
