Date/Time: Thu, 09 May 2024 17:44:05 +0000
Weekly OHLC Study
View Count: 1816
[2016-11-22 06:54:49] |
tradernikki - Posts: 41 |
I want to track the movement of current week's High and Low. However, the study resets each day and mark a lower high on the day after. I would like for the high to stay marked, unless broken within the same week. Otherwise, it would be no different from the Daily OHLC study. Thanks http://www.sierrachart.com/image.php?Image=1479797308879.png Date Time Of Last Edit: 2016-11-22 06:55:18
[2016-11-22 17:48:16] |
For now use the Period OHLC - Variable Period study: http://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s294 We are not going to have time to look at the Weekly OHLC study for a while. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-11-23 05:09:35] |
I couldn't get the same results. Basically, I would like to replicate these lines, but for the Weekly data. http://www.sierrachart.com/image.php?Image=1479877073829.png Any pointers? Thanks |
[2016-11-24 05:27:57] |
We do not have any other suggestions now.
[2016-11-24 06:33:10] |
Okay. Then please update the Weekly OHLC when you have the time. Will be waiting for your notice. Thanks |
[2016-11-24 18:34:16] |
Sawtooth - Posts: 3993 |
You can do this with the Spreadsheet Study study. -Put the attached Weekly HL.scss file in your Sierra Chart \Data folder. -Add the Spreadsheet Study study to your chart. -Set the Chart Region to 1 -Use the Select button next to the Spreadsheet Name field to choose Weekly HL.scss -Set the Draw Style of SG1 to Ignore. -Change the Draw Styles and colors of SG2-SG4 to your requirements. Date Time Of Last Edit: 2016-11-27 16:03:13
Weekly HL.scss - Attached On 2016-11-24 18:28:53 UTC - Size: 112.61 KB - 264 views |
[2017-02-28 05:09:42] |
We have identified the problem and we are resolving it now.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-02-28 05:10:18
