Date/Time: Tue, 28 May 2024 17:13:49 +0000
[Programming Help] - sc.flatten
View Count: 818
[2016-11-21 22:44:20] |
User222821 - Posts: 21 |
Hi is there any example how to do in acsil flatten all open positions when current time appears for example at 16:00 thanks |
[2016-11-22 05:40:18] |
This is supported in the latest prerelease through Global Settings >>Global Profit/Loss Management. Otherwise there is no example and ACSIL for this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-11-22 19:06:05] |
unfortunately when i start auto trading then it does not work when backtest it still holds position
[2016-11-22 19:08:28] |
Yes that is true. It is not going to work during back testing.
[2016-11-22 19:27:07] |
feature is disabled it is written where can i enable it |
[2016-11-22 19:28:00] |
is there any chance how to do do it or flatten position when time appears? during backtest? |
